AFC-SplitSecond PSC1 Map Library
here is a dynotuned map of a gt28rs @ 15psi on 440cc injectors.
enjoy...
edit: map was taken off b/c it was running too lean on the street. pushed it today and it was running 13.6 uptop. way too lean. i'm gonna make the necessary adjustments and repost street tuned one.
DSMConvert could probably get you another CD. I'm all packed and ready to move back to NY, otherwise I would put the .iso on my website and let you download it there.
Anyone know where I can find this AFC and for how much. The MPI tuner is a little out of my price and I am looking for something a little less but not cheap. I want it done right.
DSMConvert is the rep on the forums for the AFC; his name is John. He knows his stuff well.
I don`t know if this has been posted or not, but if someone is thinking about buying this AFC, and it is a good AFC... When you go to get a wideband (which should be one of the first things) get a Zeitronix or be prepared to spend $275 for an AEM + $extra for some sort of datalogger if you are planning to tweak/tune yourself. Just something to keep in mind...
Thanks for the info. I will have to look into that.
Where to tap the wires?
Where did you guys tap the wires? Close to the ecu connector, or the opening closer to the firewall? Friggin pain in the ass trying to work under there dammit.
Morning bump.
Just unplug the ecu from the hardness, pull the the hardness a little and start tapping the wires in the middle.
Just installed mine. It took me about 2H to install. I didn't use the wiretaps, Instead I just cutted the wire's plastic protector and rolled the wires around it before putting some isolating tape on. No soldering whatsoever so If I need to remove it it will still be possible.
How the hell was I able to live without that thing until now??? The car feels awesome! More low-end torque, less hesitation, smoother idle, better acceleration over the whole rev-range. Bottom line: That was the best money I invested on the MSP since a long time!
I just tought of it... I just setted a new record. It was rainning bad outside but I really wanted to install it today so I did it with the 4 doors closed from INSIDE the car! There was so much fug in my windows once I was done you can't imagine!
Tuner and contortionist! lol
Great job...SpeedBeaver...what other mods do you have on your MSP..I have one coming (from Canada, no less) too. Cant wait to get it...
