I just reacently bought a AEM F/IC, I have been following the forun to help me install it my self but found that there are some issues with the wireing diagram posted. I have found the sensors are indead MAG style sensors although they do have three wires (crenk) comming out of it. (the cam is also MAG) i will post a wireing diagram hopefully this weekend with the correct wiring.
I did see some had issues with taping the maf sensor. the AEM F/IC has to be set to reading percent and not voltage before you start the car. then get your base line and clamp your sensor before you add any boost to the configuration.
I will keep you guys posted as i progress in my install.
