smithers_0990
On and On
- 02 P5 & 01 Audi S4
Abs Cai? (pic inside)
ABS plastic CAI
For those of you with a ABS CAI could you explain what different degrees you used to make it? A tight 90 then a straight then a normal 90 to another normal 90 down?
Also what did you do with that rubber tube comming out of the stock rubber intake that goes to the side of the engine?
Sorry it doesn't make much sense. But what I want is directions on how to make an ABS plastic Cold Air Intake.
Thanks
ABS plastic CAI
Thanks
