TippytheHippy
- 2008.5 White crystal MICA Mazdaspeed 3
Big to me anyway LOL!
9-3-2009
Hello Everyone!
I have a 2008.5 MazdaSpeed 3 CWM. I haven’t started much on my car. I followed the stereo upgrade that was posted here by 6262MS3 (thanks), but it wasn’t enough. I wanted more. I have installed some really nice rims size: 18x8- 5x114.3/112/120 by RPM. They have 38mm offset and I eventually had to roll the fenders. I have an Eastman roller BTW for sale (SORRY SOLD!). Looks great and the rubbing is gone. I also made some Carbon fiber Decals like the stripes posted here. I hard installed a Valentine One. Oh yeah, I installed the Jack site stealth box.
I decided to install a stereo. Back in the day (twenty yrs ago wow), I had a 76 cutlass Supreme with 2 Fosgate pros and a Fosgate Power 650… One bad system I swear. Anyways, that was then this is now and is why I have decided to go Fosgate. Although I do realize they are nothing like they used to be (in my opinion).
I went a little wild and bought a whole bunch of equipment. Here are some of the things I will be installing: 2 2 ohm Pioneer Premier TS-W3002D2 3000 watt , 1 Power 8” and a stealth jack box, 4 amps (2 P1000-bd & 1 P400-4 & 1 P200-2), 2 Power 5x7 for the front , and 2 Infinity Reference 5x7 for the rear (because of the directional tweet to bring the stage higher. I would like my riders to enjoy full sound level as well).
I also purchased 1/0 power and ground with nice gold plated distribution blocks and connectors. I have 100 ft of sound dampening material and nice rollers to apply. A buddy of mine works at the Arnold Air Base designing things. He gave me a heavy duty 500 Farad Cap that can be untaped and put in any shape I need.
I also decided to keep the factory head unit and NAV. I purchased (by accident) A JL Audio Summing device thinking it was the CL441DP. So next I purchased the CL441DP. Now I am unsure if I need the summing device. The signal is phased through front, rear, and woofer. Is it Full Range from the head unit?
I haven’t tapped into the head unit yet. I did run a PAC from under the driver seat (amp) when I ran the stealth 8 and 200-2 Fosgate amp.
Well, that is about everything I can think of. I have been looking at this equipment for a couple months. I have been apprehensive about how to start. I believe the power wire will be first. I was thinking about running it under the chassis (outside) and attaching it to the frame away from any heat. I need to check and see if there is a hole under the spare. UPDATE: there is a hole under the spare but I ran the wire inside anyway.
Anyways, as you can see, I have a lot of stuff to do. I just wanted to share my build and urge anyone to comment if there are any suggestions. I appreciate your time. I will post the steps later. Thank you, tippythehippy
9-3-2009
Hello Everyone!
