You know I was thinking about everyone that has blown motors.....and I have said this before....most of them were running over 7 psi.....FMU's over 7psi are ticking time bombs.....I never ever recommend using an FMU at anything over 7psi and all the motors that blew used FMU's(RRFPR) Terry's car used extra injectors and has been fine......stou ran 8 psi with 2 additional injectors daily and his motor was fine. the key people fuel....if you plan on ANYTHING over 7 psi get rid of the FMU before you try it.......I believe seriously this is the reason most of these motors blew....ask any honda guy who knows what he is talking about they will tell you a FMU over 7 psi is a tickign time bomb....your injectors start to go static...your fuel doesn't atomize as it should......your combustions don't happen as completly as they should thus detonation and soot on your rear bumper and then persistant dentonation and then BOOM!!!!! if you ahve anFMU turbo kit AKA EVERY kit out there....I highly recommend keeping your boost lower than 7 psi and 7 psi shoudl be your MAX. If you want to go high get better fuel managment. IE eManage, Link, SDS EFI, ERL MF2, haltech FC5 something that will control fuel better than a FMU.
