- 07 Speed3, Cosmic Blue
There has been some confusion/fears installing a Pod on the A Pillar. I started my install today based on BluMicaR's install and hints. I decided to take pics with some info added.
1. First I removed the door molding and carefully started
removing the A -Pillar cover. You will see in the photo the Airbag and its relationship to the cover.
2. This pic shows how far down the airbag goes. Also the Pop/Slide clip.
3. This shows the A Pillar cover and the area than you can use if you decide to screw in the cover and not damage the Airbag.
Hopefully the weather will hold for a bit so I can finish this up. The Gauge Pod is painted based on BluMicaR's recommendations. I do think the texture of the pod throws off the paint abit, but it is DAMN close and will work fine.
I did mount my sending unit on the Battery Box for now. Once it is wired up (I still need to find the wire that will allow the white to be shown), I will post more.
![DSCN0725edit.jpg](/forum/proxy.php?image=http%3A%2F%2Fi183.photobucket.com%2Falbums%2Fx77%2FWink_LOM%2FDSCN0725edit.jpg&hash=ced4a17f5b473f9dbf1b3ea41f0eff6f)
![DSCN0720edit.jpg](/forum/proxy.php?image=http%3A%2F%2Fi183.photobucket.com%2Falbums%2Fx77%2FWink_LOM%2FDSCN0720edit.jpg&hash=64c65420cc141c59e9c957c6b5d8a55b)
![DSCN0726edit.jpg](/forum/proxy.php?image=http%3A%2F%2Fi183.photobucket.com%2Falbums%2Fx77%2FWink_LOM%2FDSCN0726edit.jpg&hash=f7423fa6ab5af7f4ea0905105fbb5f5b)
![DSCN0723edit.jpg](/forum/proxy.php?image=http%3A%2F%2Fi183.photobucket.com%2Falbums%2Fx77%2FWink_LOM%2FDSCN0723edit.jpg&hash=ef8cde5f248d134ac2f31d3f1b444d99)
![DSCN0728edit.jpg](/forum/proxy.php?image=http%3A%2F%2Fi183.photobucket.com%2Falbums%2Fx77%2FWink_LOM%2FDSCN0728edit.jpg&hash=12f169e31af1ce9f5ed9184a4e6ab923)
