D deepdezal Member : Protege Aug 12, 2014 #1 Hello Guys, I have searched the forum and I'm a bit confused as to what the issue is.. Is the fan switch gone bad or the fan resistor? Thanks in advance!! Deepdezal
P Preferio I break stuff. Contributor : 2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6 Aug 13, 2014 #2 deepdezal said: Hello Guys, I have searched the forum and I'm a bit confused as to what the issue is.. Is the fan switch gone bad or the fan resistor? Thanks in advance!! Deepdezal Click to expand... It's a well-documented problem. The cause is a burnt contact on the harness plugging into the HVAC unit. Remove the HVAC unit and look at the large (6 wire I believe) harness plugged into the back of it. Guarantee you'll find that it's burnt.
H hornsfan10609 Certified Mazda Tech : 2003.5 Mazdaspeed Protege x2 Aug 14, 2014 #3 It could also be the switch itself, it's about $35 at mazda.
