qualityrockola
Magus said:I really must have a freak P5, the AC works REALLY well in my car. I have to turn it down and turn the cold to the between cold and hot setting (and I love it freezing). The UR UDP pulley really helped the AC from draining as much power. I mean yeah, if I am AutoXing I will have it off and the windows down any way. Though everyday, the AC does not hurt as much now. The mod also helps with freeway cruizing. Maybe you guys should get your AC systems check out for low coolant or leaks.
Magus
But how often does it get over 90 degrees in MD? 90 degrees is when my AC starts losing its effectiveness.
