86 RX7 GXL (new project)
JDuncan said:
I would suspect that the 5th/6th ports are't activating correcty. On the S4's they are activated by exhaust pressure IIRC. If it has aftermarket exhaust then you might want to check to make sure provisions were made to provide that activation.
doh, you're right, i forgot S4's valves are exhaust pressure activated, the S5's uses a bunch of vaccuum tubes to do that.
yeah i just read that its 25hp ... i'll look into that
i only read a few lines but so far it doesn't look that hard to fix
this is getting exciting
Clean the gasket surface of the actuator. Shoot penetrating lube into the hole and begin to work the shaft in and out. Lube the shaft and work it in and out.
lol
