Got the headlight from Alex this evening. Jumped right to work on it and the wagon headlight template is already done. I was able to get everything fitting just like the sedan light setup. I used a jigsaw with an 18-tpi metal blade to make the cut, then I finished it off with a dremel and sanding drum to smooth it out. You can use a dremel with cutoff wheel for the cut if you prefer.
I will be shooting out a PM to you P5 guys + bwalt to see if you want a physical copy mailed to you or a digital scan emailed to you.
