lol, this is the wastegate not working properly...hes probably hitting ~10 psi in really cold weather, which can cause it...or higher, which will cause it in any weather
axis: be careful, check your wastegate....it may not show a bad vacuum, but it could still be bad....fuel cut is never good and it should not happen at stock boost in any weather
mitsman: yes they make a unichip setup
http://www.*************.com/mazdaspeed2.htm
