- MP5T / 944
Focus said:You can always weld on to the intake runners and run 4 extra injectors.
The SDS EIC-2 has worked for me very well...
A little harder to tune with, but just as effective!Brian MP5T said:![]()
I'm looking into the SDS a little bit more closing since your are running it Brian. Have you had any problems with the fuel not atomizing correctly or had any cylinders recieving more fuel than the others? I suppose not since its mounted in the intake pipe but you never know. Also, how was tuning with the stock ECU and SDS, a pain in the ass?Brian MP5T said:![]()
TurfBurn said:Here you go. Direct drop in no modfication.. BUT low impedence... supposed to be super cheap too. (about 35-40 bucks an injector) have to call a chrysler dealer to get them most likely:
Siemens Injector, 55 lb or 550cc. Chrysler Part Number: 4532586
no you just have to calibrate your EMS for them. not a problem.hello2000 said:is low impeadance bad?
EMS usually are picky about that, either they want high or low impedance.mx3ownzj00 said:no you just have to calibrate your EMS for them. not a problem.
The Microtech doesn't care... just a matter of how many injectors you can have on each driver.Focus said:EMS usually are picky about that, either they want high or low impedance.
I think the MPI likes high impedance only. Nick can answer that one better.BlkZoomZoom said:Can the MPI be switched for low impedance? I already bought the srt-4 which I was told is high. I guess we will see when I get them.
cool I didn't know you could buy the injectors seperate.BlkZoomZoom said:Stage 1.
