I joined up a few months ago in preparation of getting an '02 ES but that deal fell through. Things are looking a LOT better right now and I'm looking to bring home a new ES within the next month. I plan on setting the car up for auto x and street duty. I have no experience with Proteges so I'm going to rely on your experience so I can do things right the first time. So far I've looked around the aftermarket and there doesn't seem to be a whole lot but I don't plan on doing that much.
Question 1: I read in a thread about the ECU going into a closed loop mode with a pretty rich a/f ratio on high comp. motors because of detonation. I want to run the Mazdaspeed 10.7:1 pistons. Is there any truth to this? If it iscan it be countered with 93 octane? (we get the good stuff not that 91 pee water the Cali guys get
Question 2: Mazdaspeed header... Forgive me but I haven't been under the car yet. Heh, imagine doing THAT on the dealer lot.
I hear it replaces the pre-cat and main cat (do non California cars even have the pre cat?) And that it will throw a CEL because it was intended for OBDI JDM cars so it doesn't have a bung for the second O2 sensor. If somebody could draw me up a diagram showing how the stock exhaust system is setup from the exhaust manifold to the main cat showing where everything is located (pre cat, EGR, O2 sensor, ect). I'd appreciate it so I can get an idea of where I'd need to relocate the sensors to kepp the ECU from having a seizure. C'mon it's chance to play with MS Paint!
Discalimer: I know it's illegal to remove the cat but I plan on adding a high flow cat somewhere in the mix. And if I even get a header it WIll be this one and no the Bosal.
Question 3: Cams. Pretty straight foward mod. I'd just like to know projected gains for the intake AND exhaust cam combo.
Question 4: Racing beat exahust? How was the install? I hear it kinda a PITA.
That's about it. I don't want to do too much and the above will likely be it as far as engine mods go besides a drop in K&N. The rest will be Racing Beat springs with Tockico HP's, and some decent wheels and tires. If you can answer any of my questions you get a cookie.
