This is my first post, I wish it could be a better one.
I have a 93 323 1.8L sohc 5spd, here is the problem. Was driving on the highway went to pass and the car died when I stepped on the gas.
Got it home and check for spark, No spark at the coil. Tested everything and the coil appeared bad so I replaced it. Still no spark tried the ignitor and it is good. Had a spare ignitor so I replaced it as well. Still no Spark. Have power at the coil and at the igniter when the when the key is cycled.
What else could cause a no spark issue on these cars? I have power all over it appears but no spark. I took a good wire and put it directly to the coil with a spark plug and no result?
This is not an intermittent problem it just happened out of the blue.
Can anyone assist in this problem?
Thanks
Mark
Thanks
Mark
