2nd gear tick
Bc-386
2003.5 Mazdaspeed Protege
What would cause a repetitive tick when only in second gear?
I havent driven it further than around the block since i heard the tick. The tick is only present when the car is in second gear. Currently, from the brief test drive that i did, the clutch still remains smooth through the gears.
Has anyone experienced this?
The gear may have a damaged tooth, no way to tell unless you pull the trans and split the case.
Yay! (Hint of sarcasm)
Well the tranny is the last item for me to go through. I guess i'll be going through it soooner than planned.
I just find it bizarre that the clutch is still so smooth, the engine pull/delivery is smooth, but you can hear the noise even if the car is stopped while in second gear (w/ clutch pushed in of course). The sound, is soft "ti ti ti ti ti".
My diff had a chipped tooth and it would make a 'wahh wahh wahh' kind of groaning sound when driving slow but you couldn't hear it above 20mph. Hard to say what it is for sure but that is my guess.
