295.62hp / 276.31tq @ 10psi - Scion tC
JrTekSilverP5
02' TwoToned (Sliver/Black) MP5
for more details visit www.tCtunerZ.com
tCtunerz:
click here for more pics
10 psi.....that much ******* hp!? that sucks that our car can only make that much....minus 80 hp
WOW nice power, but those Air/Fuel #'s look a bit on the lean side. Wouldn't be
surprised to here of a "Scion boom thread" anytime soon.
You can blame that on the Mazda P.O.S> job they did on the head of the FS engine. Undersized valves, and crappy cams amungst other things. It doesnt breath as good as Honda, Toyo, Nissan heads that are on engines about 10 years more advanced.
That white Scion is SICK!!!
VERY nice numbers. It's more like 287-289whp when it's SAE corrected, but still very nice numbers. Makes me like the TC that much more.
thats a little off par with what Juan from hiboost is getting. I'd bet their numbers would be VERY close.
Scion:
2.4L turbo @ 10psi = 290whp
2.3L turbo @ 7psi = 245whp
Looks like thats right about even...give or take a little. Plus Juan still has some fine tuning and turbo selecting to do.
what does the turbo cost for the scion? i also thought they had a 200hp scion stock you could buy maybe supercharged or what??? maybe im dreamin?
p.s. I just noticed the Scion was running a hybrid T3/T4 turbo....damn...thats a LOT of air. Juan is using a smaller turbo than this and getting similar numbers. I'd hate to see what would happen with the same turbos on each motor.
It's also a 2.4L with higher compression and 160 at the crank stock. You forgot that part..(hi)
Exactly my point.
Scion:
actually the TC puts out over 265 @ 7psi (both dyno charts are posted) and this is running pretty lean, not nearly done tuning yet either.
so I wouldn't call it even, maybe close.
would be more like
Scion:
2.4L turbo @ 7psi = 265whp
but then again the toyota engine has the advantage of .1 more liters and a better flowing head, and I probably have a bigger turbo on the tC.
word, i want a tc now.. ill think ill get a white one instead of a new white Si. hope fully insureance is cheeper than a si
would be more like
Scion:
good job none the less... you have any idea of the limits of that engine before things start to grenade?
