2021 Cx-5 CE AWD since March and that Panasonic battery just sucks. I recently added a couple dash cams and replaced the battery at the same time. I went with a Duracell AGM for $179 USD size 94R (800CCA and 140min RC) and yes it's a goofy fit but it's locked down securely. The nice thing is the dash cams draw about 1.75 watts/ea. I left 2 of them running 12 hours overnight, and then did a battery test before starting it and it still showed 98% charge and 950CCA. Will be adding 2 more cams for 360 coverage. I think a 27F battery would've fit better but they are hard to find in AGM. I wanted max amp hr ratings and good reserve capacity for the purpose of the 24/7 dash cams running, the car play wireless dongle, (seems to be always powered on for that usb port in the console), and a heads up display that plugs in the OBD port that still draws minimal milliamps when the car is turned off.
