2019 CX-5 Reserve: Buzzing in Dash
so, i usually only do stop and go short distance drives with my cx-5,
The other day i was driving for over 30min (oh yeah!), and the noise disappears..
the next day it's back. Definitely seems like it has something to do with the engine's temp.
Heres the cricket noise coming from my interior.
https://youtu.be/3OuWvLnDA14
2019 CX5 Signature here. Also owned 2017 NON turbo previously.
I have this exact same noise issue. The noice follows the engine RPM, more noticeable under load and colder temperatures, goes away when you let off the gas then comes back as the engine RPM comes back down. My guesses would be fuel system related like the dampening system and or the high pressure fuel pump native to the 2.5 turbos.
Already warranty replaced the steering wheel which started peeling before 8,000 miles. Now I need to have them find this noise AND a loud clicking I’m hearing from the drivetrain/transmission/axles. Back out of driveway, turn 90 and drive off in Drive, clack clack, then I brake at the stop sign and hear the same clacking. Easiest to replicate if I aggressively accelerate in reverse then the same in drive. Throwing this in here incase anyone else has that same issue as well.
Has anyone resolved this problem?? Thank you!
