We've gotten along pretty good with our dealer since buying our CX-5 new in 2019. They've done all the oil changes. I do the air filter and cabin filter, but nothing else. Dealer has tried to, "push-sell" us expensive, "maintenance," like dif. oil change, too early brake fluid flush, etc. We passed on those after reading in the owner's book they are not required until later. SO.....now we just passed 50,000 miles. NO more warranty. We have a good local mechanic that does our work on other rigs, so we'll go there. I'd really like to hear what some of you have considered the FIRST and most needed services after passing 50K. Is there any special, "tune up," these cars need besides spark plugs? Etc.. Some feedback would be appreciated. Thank you, Dennis in E WA state.
When buying a used vehicle with unknown service (any vehicle) always assume there was no maintenance on the vehicle and start from there. Record all service by date and mileage and
keep it written in a small book in the glovebox. I attach a piece of masking tape under the hood
with is info also.
1- Change the oil and filter with a good brand not something that came out of a 50 gallon barrel
at the service center and never use a cheap filter (orange color). I always use Wix filters and
Pennsoil or Mobile 1 as an example.
2- Dump all transaxle fluids and replace with new. This includes differential and All Wheel unit
if you have all wheel drive.
3- Dump and fill tranny and change filter ( although they say LIFETIME in the manual. If it were
lifetime, why have a drain plug? Some shops can change fluid completely via the coolant lines
with a machine or you can drain and fill twice because you only get a 40% fluid change each
time. Most stays in the torque convertor in the tranny. Use only OEM fluid period!
4- Evacuate the entire engine cooling system and refill with only, I repeat, ONLY OEM fluid. This
I would have done at the Mazda dealership. It might cost a bit but it's good for seven years.
5-Flush the brake system completely right off the bat and every two years after. It's not dirt but
moisture you're trying to remove. As the brakes wear and fluid levels drop moist outside air is
introduced in the master cylinder and eventually the brake lines.
6- At 50K miles, there is probably quite a bit of carbon on the intake valves that has to be
removed. I can guarantee that as mine were loaded after 35K. Walnut blasting or hand cleaning
will have to be done lest you'll have serious issues down the road - poor mileage, lost power a
and the condition of the valves give insight into the condition of the piston rings. Install a new
OEM PC-valve at the same time. Do not ignore this as this is a major issue with all direct
injection engines as a result of junk oil and fuel. We all love to save a buck, don't we. Toss
in a can of Berrymans B12 (Amazon) at the next fuel fill up to clean pistons and rings and
any debris that found it's way into the combustion chamber after the above. It'll clean the
injectors and tips as well. DO NOT use any type of spray in "snake oil" valve cleaner.
On a side note it is wise to use original parts whenever possible but keep in mind there are some
mighty fine (Made in USA) aftermarket parts. China crap is OK if your're a serious DIY'er and don't
mind doing something twice - remember "Always time to do it twice, never time to do it right".
Follow these recommendations and it will be a fresh start with many miles of reliability.
