2018 CX-9 PCM codes...Help
Has anyone experienced the p2610 code? I had the code ran after my vehicle suddenly wouldn't start, and when jumped off the engine light came on. I changed the battery after reading the code and finding my battery at half the voltage it should be. After the battery change, I now have 9 codes.
p061B
p0446
p0037
p0102
p0031
p0403
p0010
p0340
p0134
Any advice would be appreciated.
How does the vehicle run? If it's running OK I would clear the codes and see if any come back. A low or dead battery can cause all kinds of codes to be set and when remedied a lot do not come back.
No power in acceleration, shaking above 30. Air conditioner doesn’t blow cold. The codes changed after the good battery was installed and tested.
You are getting O2 sensor, MAF and EVAP codes but the one it seem you need to dig in to is the p061B as it seems that is the only one you have that is not standard OBD. On the older Ford drive trains that was related to Internal Control Module Torque Calculations. Whatever of the other codes cause that would be a good place to start.
Latest posts
