From Seven Turbos, Three Hybrids Share Wards 10 Best Engines Honors, The Class of 2017 in alphabetical order:
3.0L Turbocharged DOHC I-6 (BMW M240i)
1.5L DOHC 4-cyl./Dual Motor EREV (Chevrolet Volt)
3.6L DOHC V-6/Dual Motor PHEV (Chrysler Pacifica Hybrid)
2.3L Turbocharged DOHC 4-cyl. (Ford Focus RS)
2.0L DOHC 4-cyl./Dual Motor HEV (Honda Accord Hybrid)
1.4L Turbocharged DOHC 4-cyl. (Hyundai Elantra Eco)
3.0L Turbocharged DOHC V-6 (Infiniti Q50)
2.5L Turbocharged DOHC 4-cyl. (Mazda CX-9)
2.0L Turbocharged DOHC 4-cyl. (Mercedes-Benz C300)
2.0L Turbo/Supercharged DOHC 4-cyl. (Volvo V60 Polestar)
Putting a 4-cyl. engine into a 7-passenger CUV doesn’t usually send a thrill up the leg of automotive journalists, but Mazda worked some real magic with the new Skyactiv 2.5L.
Direct fuel injection and an ingenious cylinder-head design allowing scavenging of exhaust gases to boost power and efficiency help this engine deliver excellent low and mid-range torque like a big V-6, and it had some of us checking under the hood of the new second-generation CX-9 to make sure it wasn’t.
Mazda has built its “zoom-zoom” brand image on new, technically savvy Skyactiv engines over the past several years, but this is the first one applying forced induction.
The automaker claims an industry first with its Dynamic Pressure turbocharger, which uses a butterfly valve in the exhaust plumbing to create more pressure at low engine speeds, helping the turbo spool up more quickly and mitigate lag.
Mazda advertises two output levels for this 2.5L 4-cyl. – 227 hp with regular unleaded and 250 hp with premium 93-RON fuel, for the driver who occasionally wants a bit more jump.
