2016 US CX-5 Audio System with bluetooth but without Center Display Upgrade
Sharing my information:
Factory unit was Type A 2015 Panasonic CQ-JM74E0JM not compatible with Harmony Audio Compatible with 2013-16 Mazda CX-5 HA-707903 Factory Stereo to Aftermarket Radio Harness Adapter Plug/Scosche MA03B Compatible with Select 1998-15 Mazda Power/Speaker Connector / Wire Harness for Aftermarket Stereo Installation with Color Coded Wires
Installed backup camera NATIKA Backup/Front View Camera White
Replaced with Double DIN Boss System.
Connections:
USB: B09BCH4SRD RED WOLF Car Radio Stereo Retain OE Factory USB Port Retention Harness Wiring Cable Adapter for Toyota 2012-2018, Lexus 2013-2015, Subaru 2013-2016, Honda 2015-2019
Antenna: 40-HD10 Metra Electronics 40-HD10 Factory Antenna Cable to Aftermarket Radio Receivers for Select Honda/Acura Vehicles
Main Connector: B07S9J952H RDBS 20-pin Headunit/Radio Wiring Harness with Steering Wheel Switch Wires Compatible with 2007-2019 Nissan | Upgraded Version of The Metra 70-7552 | Harness Includes VSS and SWC pins
Bluetooth/Aux Connector: Not connected. So losing SWC Speak/call/end call and Aux Audio Port currently. Installed new microphone.
SWC: PAC C4RAD Car Radio Steering Wheel Control Module SWC Retention (only Analog1 connected)
New Audio System Housing: Metra 95-7522B Double DIN Dash Installation Kit for Select Mazda CX-5 2012-UP Vehicles
I used a Kenwood Excelon DMX8905S with a iDataLink Maestro RR in my install. Amazing pieces of kit. I even get full gauges right on the face of my radio.
Connections:
Hey, thank you for sharing this information, however does your vehicle have the command center control knob? located right below the shifter, which is responsible for increasing volume, scrolling etc..? Because I would like to know if a harness or some sort of wiring is needed in order to retain those factory settings?
