2016 Mazda CX-5 Air filter replacement interval?
2016 Mazda CX-5 Sport & 2010 Toyota Corolla LE
I just took our '16 CX-5 to the dealer for an oil change at around 86k, and they suggested I replace the air filter. So, I had changed it around 70k. I believe these Mazda air filters are good for about 30k?
more or less. It all depends on how dusty is the area you live. Tell them you replaced it yourself and thats is. You can always look at it and see if its very dirty or not yet
Money grab, just do it yourself for fraction of the $ and about 5 minutes of your time.
But also, as cz5gt said, it really depends on where you live and the environment.
Unless you live/drive on dirt roads, I would just go by 30k mile change.
Changing filter too often is actually detrimental to engine protection.
How much did the dealer want to charge for replacement? They probably up charge like the cabin air filter. $90.00 to replace the cabin filter. No thanks, $10.00 on Amazon and 5 minutes work.
Same with the engine air filter.
I didn't bother to even ask for the price. I always do it myself and the car is not driven on dusty roads. Normally I just wait till 30k to replace the filter and always use the Mazda branded filter.
Also, replace the Cabin filter myself as well. Pretty easy to do.
What do you guys think of washing your engine filter to get some more life out of it before replacing?
I’ve heard using a power blower or compressed air to blow the dust off from opposite air flow direction to the air filter. That would make sense, and should prolong the filter life a bit. I’m not sure about using water to wash it.
But I do remember a previous Moderator here said he always washes the cabin air filter and reuses it. That I don’t mind as cabin air filter isn’t for the engine. ;)
A new engine air filter will cost about US$ 20?
What are the costs of a damaged engine?
Do you really want to take that risk?
Detrimental? 😂
Detrimental? 😂
I wouldnt say detrimental, but there’s a con. Brand new filters do not filter as efficiently as those some use. They filter more after some clogging if that makes sense. No real benefit to changing them more often than necessary.
I’d never clean them, they are meant to be disposable items. Check it every oil change and if it looks dirty, replace it. It’s $15. EPAuto GPA0A (PE07-13-3A0A) Replacement for Mazda Rigid Panel Engine Air Filter for SkyActiv Mazda 3 (2013-2018), Mazda 6 (2014-2021), CX-5 2.5L (2013-2024) Amazon.com
And I would not use K&N filters, the oil they use on it can foul the maf sensor.
For 2016 CX-5, owner’s manual says the “Schedule 1” change interval for air filter should be:
Replace when any equivalent timing of replacing engine oil.
(Max interval:36 months/60,000 km (37,500 miles))
Your dealer must think it’s a good equivalent timing to change your air filter when they‘re changing engine oil. 🙄
They also just don't filter as well. Track cars looking for an edge, sure. Daily drivers wanting to keep their oil clean, not worth it.
Well, I think the dealer wants to make quick profit and probably charge me like $60 to change an air filter. I follow the 36-month schedule and will replace it with the Mazda branded filter.
So, let's say I only drive about 20k during the 36 months. Can I change the air filter a year later or when I hit 37k?
For warranty purposes, whichever one comes first (time or mileage).
OP’s '16 CX-5 with 86K miles has no warranty now, and he can change the air filter whenever he prefers. :whistle:
For air filter, I believe the mileage used should be the only consideration with driving environment. I wouldn’t bother how long the filter is being there, unless it’s been there for 5、8 years.
👆 This.
I can go into a long spiel about it, but I'll save everyone from falling asleep unless someone is interested.
