2015 Mazda CX-9 Caliber Pin torque specs?
Does anyone know the front caliber slider pin torque spec for 2015 mazda cx9? I found Someone on google say its around 25 ft lbs and I'm seeing others saying 50 + ft lb
Ha, its not much. Probably below 25ft-lbs. Dont know why but caliper slide pin bolt spec torque is always scary lite
You want to be careful on this. On newer Mazda’s it can be 23~28 ft-lbf (front single-piston caliper) 、62~68 ft-lbf (front dual-piston caliper)、17~22 ft-lbf (rear caliper). It’s very easy to strip the threads or snap the bolt if you used a bit higher torque.
Latest posts
