2014 CX-5 Loud and Revving (sound) when starting to accelerate
I have a 2014 CX-5, just had the muffler and mid pipe replaced along with front and rear sway bars. The car is loud upon moving and as I accelerate it sounds louder as if it is revving.
With the car running can you, or someone else, look and listen under the car while you rev it a bit to see if the source of the sound can be found? Check under the hood too.
Upvote 0
I have a 2014 cx5, just had the muffler and mid pipe replaced along with front and rear sway bars. The car sounds upon moving and as I accelerate it sounds louder as if it is reving.
Where did you have the exhaust and sway bar replaced? If not a Mazda dealership, do you know if the replacement parts were genuine Mazda parts or aftermarket?
Can you let the folks who did the work for you know that it seems louder to you now?
Upvote 0
