2013 Mazda CX5 Headlight off timer config
Devorkin
Mazda CX5 Luxury (2013)
Hi!
I own 2013 Mazda CX-5 Luxury (2.0L 165hp).
Our dealers here don't have much of deep knowledge with the CX-5 or they don't want to share it at least...
I wanted to configure the headlight timer to be on for 30 seconds after turning off my car but couldn't saw this option (and several others) in my audio system.
After going to: setup --> Vehicle --> Lightning
The only options I see there are:
- Int. light timeout - door open
- Int. light timeout - door close
- 3 Flash turn signal
What can I do to reveal more options? may it be that I've got my system with lack hardware? or a firmware version maybe (which I can install using a dongle or something)?
Also, I don't know if its related, when playing music via BT there is 1-2 seconds delay between the time I press action button (rewind, forward, pause, etc...) until it happens.
Hope you'll be able to assist,
Thanks in advance!
Sincerely,
There is no such setting for the headlights.
That delay in Bluetooth is there for all CX-5s, so it's "normal".
Sorry you're right.
I have a 2014 Touring with Tech (USA) and I have the headlight timer setting.
Maybe it's not available in your trim and/or country.
The delay in bluetooth music is because our CX-5 bluetooth is POS. It doesn't have to be this way, as all my other bluetooth stream devices (Moto Stream, generic bluetooth speaker, Bose soundlink2) are all instantaneous.
I remember the car has to be ACC on (or engine on) in order to access some config menu, but I think you are already in that menu. Maybe it's disabled by firmware.
