2013 CX-5 Traction, Tire Pressure, Check Engine Light, Trouble Running
Hello,
traction control, tire pressure light, and check engine light came on all at the same time.
the car barely kept minimum rpm and shuts off.
when I scan the car I didn't get a misfire code.
just got
P0102 mass or volume air flow sensor a circuit low
P061B internal control module torque calculation performance.
someone else has experienced this and had a fix or has suggestions on how to fix it?
Thank you
Yep, check the battery. Is it the original battery that came with the car? If so, it's due for replacement anyway, so that would be where I'd start.
Concur, likely the battery, no matter how new or old it is. Modern vehicles with all their computers are very sensitive to voltage levels under load. Be certain to electronically load test the battery, not just a voltage check. Stores like AutoZone will do it for free.
Thanks, the thing is the battery looks fine, I check voltage and got a 12.7
And the car starts with no issue.
What's the running voltage, assuming you can keep it going long enough to check it?
The fact that three unrelated lights came on simultaneously might mean something you might be able to clear along with the codes, etc. by a cold shutdown. Remove a battery cable long enough for all circuits to die down then reattach and try to start it.
Maybe a code that makes some sense will come up.
You might have trash or dirt on mass air flow sensor. There are some threads on how to check/clean it...
Hello,
just got
Thank you
Please let me know what did you do to fix it. Thanks
In fact, my co-worker's '14 Mazda3 had bad MAF sensor also.
Easy to replace DIY with parts purchased online.
I am watching my own '14 Mazda3 closely.
Hello,
just got
Thank you
I had a similar issue, do you have issues shifting from park? if you have push button start, does it take a few tries to make it turn green?
Hello,
just got
Thank you
A few months back I had the same issue, all lights began flashing and could not go over 20mph. I ended up scanning the codes and was able to determine a misfire. I changed the coil packs and spark plugs since it had been a while.
Latest posts
