I completed the first oil change on our CX-9 last weekend. It was 4 months after purchase, with around 2,500 miles on it.
I already had 5 OEM oil filters, that I ordered for cheap. (mistake?)
Just like everyone else, I had a helluva time getting the oil filter off, that thing was torqued down. The filter was all banged up by the time I got it off. I had to use a wrench to unscrew it, the entire time. It never got to the point where I could unscrew it with my hands.
So, I went to install a new OEM oil filter, and expected to be able to hand tighten it...wrong. After a couple rotations, it got tight and I couldn't tighten it with my hand anymore. (it was not cross threaded) There was still a good 1/2" before the oil filter would even seat. And of course, I didn't have an oil filter wrench that fits the stupid OEM oil filter grooves, so I had to use a universal wrench to try to tighten it up. I never could get it all the way on, so I backed it back off, and went to Autozone for an aftermarket Oil Filter, and bought an oil filter wrench that fit the grooves for it.
Came back home, and installed the aftermarket oil filter. The entire time, I had to put a lot of pressure and torque on it, just to get the oil filter to seat.
Is this normal? I'm afraid that the threads may be stripped from factory torquing down the first oil filter. I thought these things should be able to hand screw on with no wrenches necessary (like every other car I've changed oil on).
If the threads are stripped, I'm not even sure if I have a case, if I went to the dealership and asked them to fix it? Can that middle, threaded part where the oil filter screws on to, be replaced if it is stripped?
On a brighter note, I put in Amsoil Signature Series 5w-20. My wife is on about 1/2 tank, and she says she is getting almost 1mpg better than before. This is just computer average, so it isn't completely accurate. I will hand calculate at fillup, but she seems to think she is getting better mpg so far
I also installed the fumoto valve, to make the oil sample for oil analysis easy to draw, and for easier draining. I plan to go 5k miles on this Amsoil before I take a sample.
Thanks!
Thanks!
