2008 CX-9 po203 and po0097 codes
Having some issues with my CX-9...My wife had the check engine light come on and flash. I scanned for codes and got po203 which is injector open circuit on cylinder # 3. I cleared code and it hasn’t come back. Now when u drive at 4th to 5th gear I get a slight vibration. It almost feels Ike a shutter but I’m wondering if that injector code is related, possible misfire. I also notice the po0097 code which may be unrelated. It’s for an air intake solenoid. Any advice?
I'd recommend pulling that injector and checking the resistance. There are several threads on here about injectors.
Here's an example:
Here's an example:
Great, thank you. I just thought it was odd to feel a shutter between 4th and 5th gear. I guess it’s possible if an injector is misfiring.
New Threads
