2008 cx-9 GT roof rack
mrcheeksnj
2008 mazda cx-9 GT
I just purchased a '08 Grand Touring cx-9 which had an aftermarket roof ski cargo rack installed. I removed it because I do not need it. I noticed there are 3 sections on each side of the molding. Of course only 2 were being used. The 2 on each side that were being used has a black bracket which the screw tightens in for the roof rack. They protrude and stick out past the molding. If i buy the clips to cover them, they will not fit. I'm not sure what I can do to the brackets. On the other clip which isn't being used, the bracket is under the molding so the clips cover the bracket.
The piece that protrudes should not be there.
Can you take it off?
There were plastic covers to cover these holes.
I had them but gave them all away.
