Maybe, but removing the plastic guard panel is quick an easy. With a small powered screwdriver, it takes less than a minute, and it gives you access the entire underside of the engine.Medicman said:Could one not just cut a round hole under the oil filter to save some time ?
make it a little larger than the size of the filter ?
Enought space to tighten/loosen the filter with the tool ?
Also, the whole you would need to cut out would have to be quite large, and I think it would expose the oil filter to dirt from the road.
