Whats new for 2005
LS2 6.0L engine replaces LS1
400 horsepower (295 kw)
395 lb.-ft. of torque (546 Nm)
Available hood with twin air scoops
Revised rear fascia incorporating outlets for new split dual exhaust system
Polished exhaust outlet tips
Larger brake rotors and calipers
Red-painted calipers with GTO logo on front caliper
Driver foot rest
Two new colors: blue and grey
Model Lineup
Engine Transmissions
6.0L V-8
6-spd man
(Tremec T56)
4-spd auto
(Hydra-Matic 4L60-E)
GTO
s
o
s
Key:
Standard
s
Optional
o
2005 PONTIAC GTO: THE NEW GOAT GETS MORE MUSCLE
GTO the original muscle car was re-introduced last year and returns with more power and style for 2005. A new LS2 6.0L V-8 engine replaces the LS1 5.7L engine, bringing with it an increase in horsepower and torque.
The 05 GTO packs 400 horsepower (295 kw) up from 350 horses (261 kw) and 395 lb.-ft. of torque (546 Nm), up from 365 lb.-ft. (495 Nm). Transmission choices are the same as the 04 models: The Hydra-Matic 4L60-E four-speed automatic is standard and the Tremec six-speed manual is optional. GTOs more powerful engine should lower the 0-60 time to less than 5 seconds.
Enthusiasts will immediately spot the brawnier 05 GTO, thanks to new badging and a revised rear fascia that incorporates a new dual-exhaust system it splits the GTOs two outlets, routing them to opposite sides of the rear fascia. The exhaust tips are polished for a more refined appearance.
Also available is a new hood design incorporating a pair of stylish air scoops. The scoops draw fresh air in to the GTOs engine compartment.
The badges identifying the 05 GTOs bigger V-8 include a 6.0 badge on the trunk lid and revised GTO fender badges, which now incorporate 6.0 Litre designations. The original 1964 GTO also wore 6.0 Litre fender badges, but at a time when almost every other American manufacturer referenced engine size in cubic inches.
Along with the GTOs power increase comes improved braking performance from larger brake rotors, calipers and pads. The calipers are painted red and the front calipers feature the GTO logo.
Additional changes to the 05 GTO include two new colors (blue and grey), as well as driver foot rest. A line of regular production accessories (RPAs) based on the 2004 GTO Performance Plus SEMA concept vehicle is scheduled for start-of-production availability. The accessories include a tall rear spoiler, front and rear fascia extensions, rocker molding extensions and grille inserts. As part of GMs RPA program, the accessories can be ordered and installed on the vehicle prior to delivery.
LS2 details
Compared to the Gen III-based LS1, the 2005 GTOs LS2 V-8 incorporates several significant changes to help improve performance. The block is an all-new casting with cylinder bores measuring 4.00 inches (101.6 mm) in diameter. The cylinder heads and camshaft are revised, too, to deliver the airflow necessary to complement the engines larger displacement. Other changes include:
New aluminum block casting with revised oil galleries and provisions for external knock sensors external sensors improve serviceability
Camshaft lift increased to take advantage of increased cylinder head flow
Camshaft sensor relocated from the rear of the block to the front of the block provides room for new oil galleries
Flat-top piston design with lower ring tension reduces friction
Piston floating wrist pins help quiet the engine
More efficient ignition coils require less energy to provide a comparable spark
Compression raised to 10.9:1
Larger, 90-mm single-blade throttle body
Reduced-mass water pump design with improved sealing capability
Engine redline raised to 6500 rpm
Revised and more powerful engine controller incorporates all electronic throttle control functions
Possibly the new look of the 2005 GTO
http://ultimategto.com/2004/04_00092_1.jpg
http://ultimategto.com/2004/04_00092_2.jpg
Driver foot rest
Model Lineup
6.0L V-8
6-spd man
(Tremec T56)
4-spd auto
GTO
s
o
s
Key:
Standard
s
Optional
o
LS2 details
