2005 GTO **More Power and Style for 2005**
MSP4EVER
Mazdaspeed Protege 2003.5
Whats new for 2005
LS2 6.0L engine replaces LS1
400 horsepower (295 kw)
395 lb.-ft. of torque (546 Nm)
Available hood with twin air scoops
Revised rear fascia incorporating outlets for new split dual exhaust system
Polished exhaust outlet tips
Larger brake rotors and calipers
Red-painted calipers with GTO logo on front caliper
Driver foot rest
Two new colors: blue and grey
Model Lineup
Engine Transmissions
6.0L V-8
6-spd man
(Tremec T56)
4-spd auto
(Hydra-Matic 4L60-E)
GTO
s
o
s
Key:
Standard
s
Optional
o
2005 PONTIAC GTO: THE NEW GOAT GETS MORE MUSCLE
GTO the original muscle car was re-introduced last year and returns with more power and style for 2005. A new LS2 6.0L V-8 engine replaces the LS1 5.7L engine, bringing with it an increase in horsepower and torque.
The 05 GTO packs 400 horsepower (295 kw) up from 350 horses (261 kw) and 395 lb.-ft. of torque (546 Nm), up from 365 lb.-ft. (495 Nm). Transmission choices are the same as the 04 models: The Hydra-Matic 4L60-E four-speed automatic is standard and the Tremec six-speed manual is optional. GTOs more powerful engine should lower the 0-60 time to less than 5 seconds.
Enthusiasts will immediately spot the brawnier 05 GTO, thanks to new badging and a revised rear fascia that incorporates a new dual-exhaust system it splits the GTOs two outlets, routing them to opposite sides of the rear fascia. The exhaust tips are polished for a more refined appearance.
Also available is a new hood design incorporating a pair of stylish air scoops. The scoops draw fresh air in to the GTOs engine compartment.
The badges identifying the 05 GTOs bigger V-8 include a 6.0 badge on the trunk lid and revised GTO fender badges, which now incorporate 6.0 Litre designations. The original 1964 GTO also wore 6.0 Litre fender badges, but at a time when almost every other American manufacturer referenced engine size in cubic inches.
Along with the GTOs power increase comes improved braking performance from larger brake rotors, calipers and pads. The calipers are painted red and the front calipers feature the GTO logo.
Additional changes to the 05 GTO include two new colors (blue and grey), as well as driver foot rest. A line of regular production accessories (RPAs) based on the 2004 GTO Performance Plus SEMA concept vehicle is scheduled for start-of-production availability. The accessories include a tall rear spoiler, front and rear fascia extensions, rocker molding extensions and grille inserts. As part of GMs RPA program, the accessories can be ordered and installed on the vehicle prior to delivery.
LS2 details
Compared to the Gen III-based LS1, the 2005 GTOs LS2 V-8 incorporates several significant changes to help improve performance. The block is an all-new casting with cylinder bores measuring 4.00 inches (101.6 mm) in diameter. The cylinder heads and camshaft are revised, too, to deliver the airflow necessary to complement the engines larger displacement. Other changes include:
New aluminum block casting with revised oil galleries and provisions for external knock sensors external sensors improve serviceability
Camshaft lift increased to take advantage of increased cylinder head flow
Camshaft sensor relocated from the rear of the block to the front of the block provides room for new oil galleries
Flat-top piston design with lower ring tension reduces friction
Piston floating wrist pins help quiet the engine
More efficient ignition coils require less energy to provide a comparable spark
Compression raised to 10.9:1
Larger, 90-mm single-blade throttle body
Reduced-mass water pump design with improved sealing capability
Engine redline raised to 6500 rpm
Revised and more powerful engine controller incorporates all electronic throttle control functions
Possibly the new look of the 2005 GTO
http://ultimategto.com/2004/04_00092_1.jpg
http://ultimategto.com/2004/04_00092_2.jpg
GOD DAMNIT! That thing looks even more like a ******* grand prix! Somebody needs to find the Pontiac design VP and smack the **** out of him.
i think the GTO is sleek and clean. They took a great Aussie car and didn't **** it up, I for one give the car a firm thumbs up.
It's a nice car, I'll give them that. Well, I'll give Australia that. But, I still don't think it's muscular looking enough to carry on the GTO name. Seriously, they already got a great chassis/drivetrain from Holden. How hard would it have been for them to come up with something unique for the body design? To me the thing has always looked like a Monaro with Pontiac badging.
aren't they bringing back the hood scoops, also. i read somewhere that the enthusiasts cried bloody murder when it didn't have scoops.
I like it a lot. Th only thing that I don't like is whenever I see one driving away, they have a crap load of squat. You can totally tell when they shift under normal accel, and under hard throttle, it looks like when a dog scoots its butt on the carpet. I guess some shocks would clear that up. It is fast, clean and there is no Pontiac body cladding...
I've always loved the monaro, but pontiac ****** up, the car is awesome as a holden, but to rebadge it as a GTO is just plain stupid...it looks like a V8 import. They maybe need to take some damn ideas from ford(never thought i'd say that) on what they did with the next gen mustang (the show car, cause what i've seen of the production model makes me wanna throw up) or dodge and chrysler with their new modern / retro designs IE crossfire 300c...
Boooo has the look of a grand prix boooo oh and its a pontiac. i will never buy a pontiac again after all the trouble i had with my old pontiac.
Even with the LS2, I bet its still slower than the C5. Yeah yeah, not the same class. I dont care. It's ugly and slow for the same price as a corvette. Buy a CTS-v or something if you need the cargo capacity (which is a retared excuse for buying one of these, cause I'm a big guy (6'4" 280) and I fit without any trouble into the trunk of a corvette. </rant>
I like the GTO. I like the way it drove and handled, But the inside feels smaller than my WS6. I will admit that they need to make the body more aggresive.
I almost traded my WS6 in on one. But I love my WS6 aggresive, fast, and the girls love it. I mean my wife loves it! (naughty)
anarchistchiken said:
Even with the LS2, I bet its still slower than the C5. Yeah yeah, not the same class. I dont care. It's ugly and slow for the same price as a corvette. Buy a CTS-v or something if you need the cargo capacity (which is a retared excuse for buying one of these, cause I'm a big guy (6'4" 280) and I fit without any trouble into the trunk of a corvette. </RANT>
It's about $10,000 less than a C5.
It just doesn't look aggressive enough for me. (yupnope)
Now many props on bringing back an ol' skool ICON WITH POWER!! (eekdance)!
New Threads
