I am trying to help out a friend of mine with a 2000 626, they are having a weird problem. The car is a 4 cyl. auto. The car will start right up when cold, and drive fine. After the car has been driven for a while and the engine is nice and hot, you shut the engine off, to say, go into a store, and then the engine will not re-start. If you wait about an hour, the car will start right back up as if nothing had happened. The ECU is not detecting a fault, thus no codes are being stored.
This sounds like the ignitor problem that used to be common on the V6 models, but I am not sure if the 4-cyl. engine shared the same ignitor. Thanks for any help.
