19s on a P5 ... Size Help Needed
Here is a more up to date pic. this is with goldline springs, 2.25" drop on back, 2" front drop(2thumbs)
Looks good slamdp5! How's the ride? And where did you get them(the springs that is)? And here is the P5 sitting on Sprints. Later.
Ride is pretty darn stiff on back, about the same as the sprints on the front. got them from chis at spd racing. they are identical to the eibach sportline springs. Your car is looking sweet, have you gotten use to the exhaust?? Looking good bigd(2thumbs)
so i have the goldlines on my msp..its like a 1.5 drop...if i want 19s im gonna go prob 7.5inch wide..now what offset will work? will 42mmworks? most of them are 42 i thnik
I was thinking about Sprints, any probs? I just got my 18's put on this weekend, now I need to do the suspension. Did you change out the struts also? I have too, I've got a leaking strut on the front, so I might as well do the whole car. Looking at Tokico's.
No problems with the Sprints at all, the back sits slightly higher than the front, but with the gear I carry for work it is pretty much even all around (maybe even slightly lower in the rear). I put Tokico HP's on at about 93,000 miles, and have enjoyed the set-up so far (150-200 miles/day). Later.
