ok I have had this protg a year now and i'm stumped. I've been throwing money at it. has a rebuilt head as of last week. put a used transmission in it shortly after getting it. replaced the computer. replaced every sensor I could find to replace. I know it still needs a new power steering pump. the problem I cant ever get around is this damn flashing overdrive light. as soon as it gets up to normal temp the o/d light starts flashing (goes into limp mode). the other problem is when it push it a bit it sometimes sets off the check engine light to start flashing. I'm thinking I need to replace the distributor now. but I don't know. the thing is I cant get the codes off of it. it's a 1995 built in 1994. it has a ob2 plug but it doesn't give any signal. it has a diagnostics port that also doesn't provide any code. the check engine light is on constantly and always has been. it ( the check engine light) come back on immediately even after being reset. just throwing it out there for any of you pros to tackle. i'm new here and just signed up. so please be gentle and thanks in advance.
