1995 protege 1.5 missing problem
jay boy
1995 mazda protege
Ok!my protege started missing recently only at low speeds and low rpm. Doesn't miss much when it's cold increses when hot, especially when starting off at a red light or from a stopped position. Once I get up over 25mph there's no miss. I changed plugs, wires, and cap and rotor, with no change. The miss is a sputter repeatedly then all of a sudden it's gone smooth running till the next stop. Help will be appreciated!!
Your Throttle Position Sensor (if you have one) may need to be replaced or adjusted.
my car has an internal coil where is it located and is it replaceable. any insight or experiences anyone has had with a missing 95 1.5L protege i would really appreicate hearing from you.
still havent found the problem and it seems to be getting worst. also its alot worst when the car is hot. egr valve?
Also check for vacuum leaks - cracked tubing, loose/missing clamps, etc.
