1993 Mazda 626 Leaking Oil
2XPLICIT
1993 Mazda 626 V6
Hey Guys,
Not sure where the oil is leaking from but it seeps when I park uphill it leaks alot of oil. Where do you think would be the first place to start looking. Distrubtor/Cap its not leaking at all...
There could be a lot of places it can leak from, but since you say it mostly leaks wen you park up hill, check the oil pan, the oil filter (around it also) and the bottom of your block to start. But like I said you have to over 100 different places it can be leaking from. Just trying to give you a push in the right direction.
