You should be fine with this set-up. I've done tons of research on that particular wheel and sizing and have checked and re-checked the car for fitment. I will be ordering this wheel at the end of the week myself. With a 43mm offset, your outer wheel edge will be EXTENDED roughly 15mm. There is a guy on the Mazda3 forums running 18x7.5 ET 43mm Work wheels with the Mazdaspeed springs and camber kit with zero rubbing issues. Granted, that's only a 15mm drop, but judging from the pic he has more room to go.
As far as the tires are concerned, you'll be fine with the factory sizing on the aftermarket wheel, but you may want to consider 225/40/18 at a later time.
