@Frank20BCosmo
I am pretty sure that the Cosmo box is a Jatco 4N71B. They are pretty common across most Japanese cars; 300ZX, Nissan 4WD's etc from the early 90's.
They can be built for big power (extra clutch packs, manual valve bodies etc). There are a fair few places in Aus that can do it; Keas is one of them.
As far as your speedo problem is concerned, it depends on how it is wired. It sounds like the pulse is being changed before it reaches the AT ECU (yep, the transmission is computer controlled which only complicates things.) If you are dead set wanting to use MPH then get something like an Apexi RSM to give you the right speed. This works by intercepting the pulse signal from the AT ECU instead of completely replacing it like what your conversion sounds like it is doing.
The AT ECU is just beside the normal ECU.
Thanks for the info Berty,, I am swapping interiors over shortly so I will change the cheapo KPH convertor out and look in to the Apexi RSM, your right as the one I have is fitted behind the speedo
@13B Cosmo
You're talking about doing a line-locker!? (evil)
A transbrake is a completely different thing. It puts the auto in 1st and Reverse at the same time so you can "stall it up" to bring the turbo's on boost. Once you release the transbrake button, it then disengages reverse and puts all of that stored up energy down the drive shaft. As you can imagine, stalling it up like this can only be done for a few seconds at a time before boiling the trans-fluid. It is pretty easy to put a thermo fan on our trans coolers though.
Two step launches are mainly for manual gearboxes. Using a two step, the car is given a lower rev limit whilst the clutch is engaged / and or whilst in neutral. This rev limit is usually set to something like 4000RPM (peak torque) but it depends on how the car is set-up. Once the car is in gear, the rev limit goes back up to the usual one (7200RPM). So all you need to do with a two step is to mash your foot down on the pedal and wait for the light to go green!
I have a blitz map analyser in my car which can do a type of launch control. I can set different "Volume" and "Gain" levels for by turbo depending on Road speed, RPM and throttle position.
