13 CX5 Annoying Squeak
cpolly69
01 Miata & 03 P5
Hello
I haven't posted on this forum in some years, but I could use any advice anyone out there has on this issue.
Lots of info comes up when you search this topic, but almost all of it relates to the front suspension. This noise is clearly coming from the rear passenger wheel area. It reacts to suspension travel like it's suspension, but it also reacts to the wheel spinning like it's bearing/brake/something else. I've had the wheel off and can't duplicate the noise without it on. It's not the brake squeaker BTW.
It's a confusing issue for sure. Anyone out there that's seen this please comment.
https://www.youtube.com/watch?v=HKJB8BDliLo&feature=youtu.be
Wow! That's such an in-your-face noise I can't believe that with an assistant pulling down on the body like you did while you searched around from underneath that you could not find the source .
Sounds like metal to metal scraping something like thin sheet metal.If you haven't already, I'd try lying underneath and push up and pull down and try to locate the noise.Maybe a brake rotor shield.
Thanks for all the replies.
It's the EBrake. After more messing around, I discovered I can modulate the noise and make it stop by messing with the EBrake. In fact, it doesn't make the noise if I have the EBrake on. I'll get under there and dig into it soon, I'm hoping it just needs adjustment.
https://goo.gl/photos/Cxg39E6M4UNcdDbo9
