Shifting the 08 Speed3
I live in the Northeast. Imagine my surprise shifting my NEW Speed3 on that first cold morning. Like moving a cold knife through cold butter. Smooth, really smooth. Like a frozen shift cable attached to a shift fork trying to move synchronizers and gears around in a gearbox filled with STP.
Double clutch? Ho Ho that don't work. Count to three during the 1-2 shift, don't work either. Humm let me see... I live on a hill, maybe starting off in 2nd or 3rd will work. No way. Lets try sitting in the driveway with the motor churning away until the temp gauge is in the middle. Nope the trans-axle must be warm and toasty before some semblance of normal shifting is possible.
I can tell you how many teeth are on each transmission gear by the pitch of the grind. This car has 1500 miles on it, it'll get better when the weather gets warmer. Move to California? Just drive it for 30 minutes and it's a little smoother not as good as it could be. Good design the culprit? Every gear change is different, always some difference, never a perfect gear change.
Why should I have to change the gear oil or whatever oil is in the trans-axle with oil it should have been delivered with? Synthetic oil is a possibility, it certainly works well in a motocross bike but that is a dog shifted transmission that doesn't have a ring and pinion that requires an EP lubricant.
Can't wait to start pounding on it, maybe thats what it needs.
