03 Protege5 Turbo help
johnwayne
Hi, I have this 03 protege5 with Garret Turbo install, where do you buy the suction filter for the engine, and where do you install the wastegate?
can you take the picture of your wastegate where is connect to, plus where do you buy the wastegate, I bought the car with the turbo install. I took a bunch of picture, and from the turbo there a line that connect to the engine part next to the oil pan, I'm assuming that is where the oil connector is.
Oh yea where do you get the intercooler piping at , and what diameter size ?
You already have a wastegate man. It's internal. It sounds liek you dfon't really knwo what's gotta happen. Have someone finish the install for you.
Wussup man,
First of all welcome to the forum. Before everybody starts to flame, please answer a few questions. I see you have the calaway manifold. Are you trying to do the msp turbo kit or make your own? Since The intercooler piping is diffrent with every kit it is hard to tell you where to get it without knowing your intensions. I recomend you read up in the forced induction section before somthing goes wrong.
Once you get everything pieced together then what? Do you have any type of engine management?
I just do not like to see people jump into turbo's without doing all their research and have a blown motor a week later.
Best of luck,
Rob
Ya, Rob said it. I'm not trying to be rude, but you jsut need to thin kthings out a bit first...
