This is driving me crazy! I recently had the evaporator replaced and then made the cabin air filter mod and since then I've been battling a passenger wet carpet from one degree to another. At first it was that the drain valve was knocked out of place, so I got that past the firewall and extended out some more and that helped a lot more with wetness by the center console under the dash. Now I'm chasing a strange problem where there is a small amount of moisture collecting under the corner of the floormat by the door in the morning after its been parked all night. I normally have it parked normally on the driveway so last night I tested with backing into the space which I thought would make a difference as to the location of the moisture, but alas, it's still there! Has anyone had a wet carpet problem but specifically in that corner away from the center console/dash?
Thanks!
Thanks!
