So I wanted to test my CX-5 acceleration with my G-tech to see how well it can do. I have over 4000 miles on the odo. Previously with my modified Toyota Tundra I could get a consistent 6.9 seconds with a best of 6.88 sec. I took it to the same level road as before and ran it both ways just like I did with the Tundra. I did three runs and the temperature was 78 degrees out + I had a full tank of gas. The runs were 0-60 in 8.45 seconds, 8.66 seconds, and 8.44 seconds with an average of 8.52 seconds. I know the G-tech is accurate because I used it at a drag strip and it actually was reading slightly higher 1/4 miles times than what the vehicle I had was doing consistently. This is no race engine by any means but certainly not slow especially for the mileage this thing is capable of.
Update-I ran another test today 4/14/20 with over 16k miles on the odo. This time I had 93 octane in the fuel tank and ran three tests. The first one I had a bit of wheel spin so I didn't count it in the test but I still tan a 0-60 in 9.11 seconds. The other two I ran 8.37 and 8.64 for an average of 8.56 seconds or about the same as before. The temperature was 45-degrees out so I thought for that alone it would have run faster.
