Guide #NHTSA Mazda CX-5 #TSB Listings/ #Brochures/ #Manuals
Kedis82ZE8
'15 CX-5 AWD GT w/Tech Pkg
Contributor
NHTSA Mazda CX-5 TSB Listings
#Recalls #Complains #Investigations #Recalls
2013 AWD - TSBs / Recalls / Complaints / Investigations
2013 FWD - TSBs / Recalls / Complaints / Investigations
2014 AWD - TSBs / Recalls / Complaints / Investigations
2014 FWD - TSBs / Recalls / Complaints / Investigations
2015 AWD - TSBs / Recalls / Complaints / Investigations
2015 FWD - TSBs / Recalls / Complaints / Investigations
2016 AWD - TSBs / Recalls / Complaints / Investigations
2016 FWD - TSBs / Recalls / Complaints / Investigations
2017 AWD - TSBs / Recalls / Complaints / Investigations
2017 FWD - TSBs / Recalls / Complaints / Investigations
2018 AWD - TSBs / Recalls / Complaints / Investigations
2018 FWD - TSBs / Recalls / Complaints / Investigations
2018 AWD - Later Release - TSBs / Recalls / Complaints / Investigations
2018 FWD - Later Release - TSBs / Recalls / Complaints / Investigations
2019 AWD - TSBs / Recalls / Complaints / Investigations
2019 FWD - TSBs / Recalls / Complaints / Investigations
2020 AWD - TSBs / Recalls / Complaints / Investigations
2020 FWD - TSBs / Recalls / Complaints / Investigations
2021 AWD - TSBs / Recalls / Complaints / Investigations
2021 FWD - TSBs / Recalls / Complaints / Investigations
2022 AWD - TSBs / Recalls / Complaints / Investigations
2022 FWD - TSBs / Recalls / Complaints / Investigations
2023 AWD - TSBs / Recalls / Complaints / Investigations
2023 FWD - TSBs / Recalls / Complaints / Investigations
2024 AWD - TSBs / Recalls / Complaints / Investigations
2025 AWD - TSBs / Recalls / Complaints / Investigations
Mazda Documentation
I wonder if anybody here has had that cracked rear differential issue. They appear to be recommending that you start the engine with the emergency parking brake off, which is contrary to what the owner manual states.
So are you disabling the EPB before starting? Or just follow owners manual?
Looking at the colored cutaway view of the differential components, it's not apparent to me that pinion shaft can contact the case when it's supported by 2 tapered roller bearings (the 2 orange components on the purple shaft. Anybody else think that the cause of failure sounds strange.
The cracked rear diff was updated in May to include the 2021 models.
Brochures
Owner's Manuals
2013-2017 Smart Start Guides
2013-2021 Warranty Booklets / Scheduled Maintenance
If you replace "starting" with "moving" it all makes more sense. Under some conditions, the EPB *will* disengage automatically, but mine seems to do it only when shifting out of Park. Neutral to Drive won't. I'm too much of a MT driver to ever engage the tranny before the parking brake comes off.
There must be a tiny amount of clearance inside of the rear diff case!
