I bought some Blizzaks mounted on steelies.
And then we got snow for about 2 weeks in November and December. And that was it... They sat in the garage and gathered dust. LOL
Lower front mesh grille installedFinally had temps high enough to apply the weathertech bumper topper
Before/after/comparison to my blue 21 cx5 with an eBay carbon fiber protector
Lower front mesh grill installedInstalled:
VIOFO A229 plus to ‘25 CX5 Premium Plus
Had no luck getting the power using the VIOFO hardwire kit, so ordered a DONGAR 10-A adapter and installed to the back of the rear view mirror…so simple and works great for those of us that won’t use parking mode
Car came with low wall all weather mats which lacked coverage, upgraded to
3DMAXspider Kanu front and back, much nicer coverage and look
Order OEM truck liner, not a fan of the 4 pieces , wish I ordered the 3DMAXspider for the trunk. My bad
Tymate wireless TPMS
American flag license plate frame
Waiting for temps to increase before installing:
WeatherTech bumper topper
Door sill protectors
Fortin One car starter
I just had the diff and transfer case serviced too! I also had the transmission fluid and filter as well as he oil changed.Changed diff and transfer case fluid. Easy job.
Those lower grills are such great, easy, and inexpensive upgrade!Lower front mesh grille installed
I highly recommend clear ppf on the headlights to keep them that way.Did headlight surface restoration and protection on the headlights, today.
Did headlight surface restoration and protection on the headlights, today. Used the Cerakote Ceramic Headlight Restoration kit #AH-HLKIT. Well, one of the headlights, anyway. (Only had time for one of them, today.)
Instructions are, basically: clean off as much of the surface gunk as possible, with the included wipes; sand with 2000 grit and lots of water; then sand with 3000 grit and lots of water. Could have gotten some 6000 grit, but didn't bother. In my case, I then followed up with the Menzerna 3800 final polish, to ensure the last of any micro-swirls and hazing was eliminated. Fully flush the lens surface with lots of water, wiping with several different clean microfiber cloths; then dry completely, including every nearby crevice. Apply the single ceramic wipe across the lens, then let dry a couple of hours. I watched it for 1hr to ensure no gunge from the nearby trees wafted onto the still-wet surface.
Turned out amazingly well. Impressed. The coating is supposedly a "lifetime" coating. We'll see, but it is about as transparently clear as I can detect, now. Compared to the previous ugly haziness from UV damage to the lens's coating, it's absolutely night and day.
Photos of both lenses -- one untreated, one coated and finished. Apologies for the size of these things, but any smaller and the detail and clarity wouldn't be so obvious.
Untreated RH side lens:
Coated and finished LH side lens:
If it's indeed a real ceramic coating, then no.But when the ppf fails, wouldn't it take the coating off the headlights to?
The only reason I haven't is because:Yup. All of my cars have clear PPF on the headlights. I had mine done shortly after taking delivery of my 2025.
May have something to do with the resilience of the plastic vis-a-vis the metal. Rock hits may be more readily absorbed by the underlying material of the former, thus preventing the paint from "breaking" as easily as it does on the metal surface.As to your experience with chips being more of a problem with your hood over the bumper cover, could be down to primer below and how the paint adheres to it. I do know when painting over plastic parts, there is an additive that's mixed in with the primer (or paint can't remember) that promotes paint adhesion.
Any online guide you followed?Changed diff and transfer case fluid. Easy job.
