Updates?
True! The car actually won't run if I use the stock maf, or Denso. Only runs with the Duralast brand maf hahaif it’s an older MAF sensor it could be the cause of your erratic afr and dog s*** running with humidity. Also the stock ecu requires the egr port on the intake side to not be blocked off since it is a part of the calculation for the afr. It can cause a bunch of funky issues when blocked
So, after speaking with Lentech, I did upgrade the valve body per their instructions, and I upgraded to the Raybestos clutches too. Added a friction to the forward drum also.As for the transmission, at 12 psi it’s going to start slipping eventually even if you lift off the gas when it is shifting. The stock soft internals are only going to hold around 170ft/lb at the input shaft before it starts to slip especially if still using the stock 3 frictions in the direct drum. the lentech valve body really helps with slip during shifting and only raises the ceiling at the input shaft to 190ft/lb.
Awesome! Should be good thenSo, after speaking with Lentech, I did upgrade the valve body per their instructions, and I upgraded to the Raybestos clutches too. Added a friction to the forward drum also.
While you’re sorting out the tuning I would recommend turning the boost down to 5-6 psi so you don’t risk catastrophic detonation from an errorReally hoping so!
That makes sense. I'll have to keep that in mind.While you’re sorting out the tuning I would recommend turning the boost down to 5-6 psi so you don’t risk catastrophic detonation from an error
ThanksI'll get together a parts list and send it to you. I need to find all the receipts so I can make sure I'm giving you the rights part numbers
