Quick post - DIY'ers who suffer from rusted/stuck bolts
bmninada
Contributor
2016 CX-5 AWD GT+iActive Soul Red
3 days worth of PB Blaster and Benzomatic, etc. was used to release few bolts on my 2016 Mazda 3 weeks ago.
Met a guy who works in Newark Airport and he suggested I instead try
Kroil Original Penetrating Oil​
Boy oh boy - this thing really works. My passenger side was worse and I was putting it off. Just on a whim sprayed with Kroil and today attempted to take out the bolts. Boom - little pressure and off it came.
In home I have something which is stuck for ages now. Tried there. Took 2 times but worked.
Its pretty expensive compared to PB Blaster but it works.
Kroil is great not always easy to find. My local muffler shop gave me good trick that really works take a torch heat up the bolt /nut and wick in candle wax
Isn't the fastest, in my experience. But if there's time to let the Kroil soak (say, over days) ahead of a project, it's great. Have used it on many stuck nuts and bolts.
FML, ~$50 for a 10oz can in Canada... I find its always best to use preventative measures where possible. Fluid Film every 6 months if you live in a rust best. And anti-seize on every bolt you touch.
Crayons work great too.
The company I used to work for bought Kroil in 55 gallon drums… I always wondered what the price was for that. Must’ve been a lot, cause a few years before I retired they switched to "Knock'er Loose".
I have (and have used) Kroil. But with anything I've tried it on, it has not seemed to provide much relief. I always assumed that those bolts/nuts were just TOO rusted, and that no penetrating oil would have worked.
But, I just watched that video above (thanks @GovtCheese!) and see that it didn't work very well at all there either!
I guess it's off to WallyMart to pick up some Liquid Wrench! (I need to do the tie rod ends on the 2014 car soon!)
If you want to experiment a little, try a can of Free All. I don't use penetrants often but this worked at least as good as others I've tried. With any of them it seems that time and repeated application is the key.
You're welcome. I'm just paying it forward. If you have the luxury of time, let it soak overnight. Also it stinks (though not as bad as PB Blaster imo)
I did see the YouTube, the issue is this: If you have a stuck nut and you have time, then Kroil beats others. Unfortunately, Kroil is NOT a fast solution. Its used in places where they spray and leave. Come back next day. Then it really shines.
