Replacing rear wiper
CX5
How hard is it to buy and replace the back windshield wiper? Cx5 2018 Mazda was going to charge me $36 to do it today and I was debating if it's worth just buying a replacement off amazon.
New "rubber" installed on your oem arms is the easiest. Installing new blade is easy as well and most autoparts stores and even Walmart and such will do it for free. At least they used to.
In my own CX-5, I generally replace the whole blade (not the arm part).
It's simple. Twist off of the "hooked" end of the arm, then insert the new blade in its place (reversing the 'twist' maneuver). Takes less than 60 seconds, including fumbling with the packaging.
I have purchased the OEM Mazda rubber inserts from amamzon. It's not very hard to replace them. I think I paid about $14 for the front pair
Depending on how pretty you are, most parts stores will change it for you.
I have bought just the inserts here,
Worked out well. You can also get the whole wiper.
DId you buy this part?
I bought a replacement but can't seem to remove the old one from the rear. I expected it to slide out like the ones on the windshield. If I apply any more force, I might break it. 🤦
2017 CX-3, right?
It has the same basic wiper arm/blade arrangement as on my 2016.5 CX-5.
In the 2017 Mazda CX-3 Owners Manual @ MazdaUSA, see p. 6-36 for the rear wiper blade instructions:
The rear wiper arm assembly on your vintage car ought to have a plastic cover over the end of the arm where it comes out of the rear window glass. It covers the nut that holds the arm onto the glass. That plastic cover has a "nub" on the inner edge of each "ear" on the cover.
The illustration on p. 6-36 shows how to gently bend the "ears" outward away from the arm and then lift-up the cover (while holding those "ears" outward). Once that cover has been removed, the rear wiper arm ought to move freely, allowing you access to remove the blade off the arm. Swap-in the new blade or blade rubber, put the arm back down, and snap that black plastic cover back onto the arm.
2017 CX-5, right?
In the 2017 Mazda CX-5 Owners Manual @ MazdaUSA, see p. 6-36 for the rear wiper blade instructions:
Appreciate this!! My rear wiper is as vintage as the car. Can't believe I never looked for help on this in the manual. 🤦
